Backup Battery Relay Sanity Check
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46967
Printed Date: May 06, 2026 at 10:55 AM
Topic: Backup Battery Relay Sanity Check
Posted By: ak96ss
Subject: Backup Battery Relay Sanity Check
Date Posted: January 05, 2005 at 11:03 AM
OK, I'm getting ready to install a backup battery in my 1991 318is for the Alpine SEC-8048 alarm system I put in. Will the set up below work to
  • Isolate the backup battery to prevent draining it if I leave my lights on, and
  • trigger the alarm when main power is cut.
posted_image
Thoughts? Did I get this right? How large a diode should I use to protect the circuit that leads to the alarm's backup battery connection? I've got the parking lights isolated with a relay, so the backup battery should only be running the main unit and the siren.
Thanks!
John
Posted By: promodeepcycle
Date Posted: January 11, 2005 at 5:11 PM
that is way wrong.... sorry....
dont be a pet monkey ..use your dmm
Posted By: ak96ss
Date Posted: January 11, 2005 at 5:17 PM
Hey, thanks for the constructive criticism.
I've modified the circuit already, gotten some help from another forum where some folks actually help others learn a few things.
