95 Lasabre door lock/unlock
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=51606
Printed Date: May 08, 2026 at 12:41 PM
Topic: 95 Lasabre door lock/unlock
Posted By: wop7
Subject: 95 Lasabre door lock/unlock
Date Posted: March 09, 2005 at 9:09 AM
Hi, I'm new to all of this so please forgive me for my lack of knowledge. I saw the diagrams for unlock and lock with  and without an alarm system. I have right now a Code alarm in my 95 Lesabre and I would like it to auto lock and unlock when I start and shut off the car.
Can someone point out the right complete set or relays to wire up and what color wires I would hook them up to?
I guess the best place to put this set of relays is under the dash right?
Thanks...
Oliver
Posted By: thepencil
Date Posted: March 09, 2005 at 9:46 AM
You can start with the diagram below. Ask question if you are stuck on the install.
You can place the relays anywhere you find room. Make it neat and tied it up so that it doesn't interfered with any moving parts underneath the dash.
Power Lock            lt. blue    +   either kick panel
Power Unlock          white    +   either kick panel
posted_image
DIRECTWIRE™ WIRING INFORMATION - BUICK / LESABRE / 1995 / Security
12volts red    +   ignition harness
Starter yellow    +   ignition harness
Ignition pink    +   ignition harness
Lock Motor gray      drivers door harness
Unlock Motor tan      drivers door harness
Disarm Defeat tan      passenger door harness
Parking Lights+ brown      low in drivers kick panel
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger dk. blue or white    -   drivers door harness
Dome Supervision use door trigger
Trunk/Hatch Pin ORANGE / black    -   trunk light or switch
Notes: Models with a trunk ajar indicator have a RED / black low in the drivers kick panel.
Hood Pin
Trunk/Hatch Release BLACK/ white    +   low in drivers kick panel
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm lt. green    -   drivers door harness
Disarm No Unlock
Tachometer PURPLE / white   AC   ignition coil
Notes: You may also use white at the back of the instrument cluster.
Horn Trigger black    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: Yes Type: VATS Part #: 652T resistor pack
Notes: See DirectFax document 1049 for interface information.
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Posted By: wop7
Date Posted: March 09, 2005 at 10:01 AM
Thanks for the helpfull and quick responce. I will give it a try.posted_image
Oliver
