550esp Viper Alarm, remote start problem,
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=5573
Printed Date: May 09, 2026 at 1:45 PM
Topic: 550esp Viper Alarm, remote start problem,
Posted By: joelr7309
Subject: 550esp Viper Alarm, remote start problem,
Date Posted: November 17, 2002 at 8:18 PM
I hooked up whole alarm and for some reason it doesn't want to remote start, it does even try to start up, I bypass the manual transmission, but still no start, I'm not sure if it the relays or the head it's self, how can I test this?
THE ROOKIE!~
Posted By: djfearny2
Date Posted: November 17, 2002 at 8:26 PM
check your tach,. one
make sure you have learned the tach. for dei alarms to learn the tach you start the car and within the first ten secons press and hold valet switch until it lights up than release count to ten and you can shut off the car and test. if you have a hood pin  it can not see ground, and if you nuetral safety is connected just simply either add a switch to control working ability or ground the wire there is a few things tell me the type of alarm you can email me for help.
Jon
Installer/Help Technician
---coral springs florida---
Date Posted: November 17, 2002 at 8:27 PM
sorry yea viper has to be learned before start do what i said and try it outand make sure hood pin is pressed and no ground is pulsing through it and neutral saftey is either grounded or on a switch ,  i usually ground it unless other wize asked,.
Jon
Date Posted: November 18, 2002 at 3:17 AM
Thanks Jon,
Yea that was it, The Tach, It was the wrong blue wire and then found the right one and it need some programing and then it fired up, Thanks Dude, Nice to get some help from other folks!!!posted_image
THE ROOKIE!~
