99 silverado keyless entry relay question
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=56645
Printed Date: May 02, 2026 at 8:54 AM
Topic: 99 silverado keyless entry relay question
Posted By: slimthug30641
Subject: 99 silverado keyless entry relay question
Date Posted: May 29, 2005 at 8:00 PM
i just bought a KE100 Bulldog keyless entry i do not have power locks at all. i have all the wires hooked up right (power,grnd,ect) but it wont lock, i got it to unlock by adding a ground to the other door lock wires so now it only unlocks.I need to know what to do to make it work like what kind of relays and which way do i hook up the relays if any body knows please tell me thanks.
Posted By: KarTuneMan
Date Posted: May 29, 2005 at 10:06 PM
Wire your relays like this -------------
Date Posted: May 31, 2005 at 6:37 PM
i tried that and it did not work does it matter what kind of relay i got.
Date Posted: May 31, 2005 at 9:05 PM
A standard 30/40 amp Bosch relay.......
Date Posted: June 01, 2005 at 9:24 AM
Where are you picking up the lock and unlock wires??? They are found at the keyless module under the dash, left of the column....Lock/lt.blue unlock/white in the brown connecter
Date Posted: June 01, 2005 at 2:42 PM
But i took my door panal off and the locks where not hooked up so i just ran wire to my bulldog keyless entry
Date Posted: June 02, 2005 at 6:08 PM
I do not have power switchs i just have aculaters in both of my doors that are not wired. if you give power to one wire and ground the other they work, so i just took the unlock wire from the ke100 and taped it to the unlock wire on both of the aculaters and grounded both of the lock wires. so are my aculaters type A or what.
Date Posted: June 02, 2005 at 6:19 PM
I must not have understood your original post....heres how to wire your realys to control the aftermarket actuators....In the picture here you can hook up BOTH actuators to the outputs (pins30)-------------
Date Posted: June 03, 2005 at 2:53 PM
I tried it that way and it just keeps blowing fuses i also tried it the 3 positive way i think it might be my relays
