2 trigger arm and disarm?
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=57699
Printed Date: April 29, 2026 at 3:54 AM
Topic: 2 trigger arm and disarm?
Posted By: yamathegreat
Subject: 2 trigger arm and disarm?
Date Posted: June 14, 2005 at 7:52 PM
ok so heres what im trying to do. when i arm my alarm i want to turn several items on and then turn them off when i disarm it so i figured i have a - arm and a - disarm puls output on the alarm what i would like to do is have these trigger relays. i was going to use the diagram below except if i do use this if i disarm my alarm twice it will turn on the systems (this is if i run the disarm and arm outputs to the same trigger input on the relay) im sure there is an easy way to setup an on and an off trigger on a relay i just cant seem to find it!
posted_image Latched On/Off Output Using a Single Momentary Pulse
Similar to the momentary to constant configuration above, we can engage and disengage the latched output with a single pulse from a switch or an output from an alarm or remote keyless entry. The first pulse from the switch will engage the latch. The next pulse from the switch will disengage the latch.
posted_image
Posted By: auex
Date Posted: June 15, 2005 at 12:09 AM
Ever hear of a "ground when armed" wire??? Just use this wire to activate 1 relay and it will turn on with the arm and turn off with disarm.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: Theshadow27
Date Posted: June 15, 2005 at 11:48 AM
like auex said, if you have a "grounded when armed" wire, use that. if you dont, because you have 2 outputs you can make a 2 relay latch/unlatch.
Date Posted: June 15, 2005 at 12:02 PM
posted_image
Date Posted: June 15, 2005 at 12:54 PM
thanks for all the help guys i know what im doing now
