Voltage Regulator/Relay Problem.
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=59071
Printed Date: April 30, 2026 at 5:49 AM
Topic: Voltage Regulator/Relay Problem.
Posted By: amb4life
Subject: Voltage Regulator/Relay Problem.
Date Posted: July 08, 2005 at 1:33 PM
Ok here is my story. I have a 2002 Chevy Trailblazer with a 160amp alternator and factory battery (test in perfect condition) I have serveral electronics in my car ie 3 amps (5000 watts True RMS US AMPS) 6 screens , Navigation, Neons, HID's (Hi/Low) pretty much most of the big stuff. I am currently redoing my interior so all the audio equipment is out of the car ( amps, tv, speakers) however in the last few days i have noticed soemthign wierd the vlotage meter on the dash has been floating up and down between 11 volt and 14 volts ALL the TIME UP AND DOWN UP AND DOWN. My first thought was shhh my alternator is going out ( I KILLED IT) so i hooked up a volt meter from the battery and ran the wire inside to monitor it sure enought the dash meter was correct about 11 volts to 14 up and down ALL the time. This morning i go to start my car and i hear a few clicks and everythign dies (lights alarm and the key wont even come out of the ignition) so i assum the battery is dead and the alternator didnt charge the battery. I get a Digital Voltmeter and put it on the battery . Soon as i put the volt meter on the battery i hear a few more clicks and then my meter starts to work and shows 12.5 volts. I take the meter off and go into the car and hte lights are on everythign is back to normal. i go to start the car and now the voltage is working perfect no drops or fluntuations in voltage.
Is this a voltage relay or regulator? Thre clicks i heard sound like a realy click not a starter click or engin click.
Thank you in advanced for the help ....
Eclipse 5435
US Amps Merlin MD2 x 2
US Amps Merlin MD42
Kicker Solo X 18"
MB Quart QSD216 x 2
Posted By: genehewett
Date Posted: July 10, 2005 at 5:17 PM
   Hi amb4life. First off let me say this. A problem of this kind is very hard to find and fix if you can't make it duplicate the problem. With that said, I think you have a intermittent connection (poor connection) in the charging system. This is based on your discription of the problem, what happened when you tried to test the system, and my own experiance. I do have a few questions that would help someone to better offer advice on what to do. (1) When you said the voltage was "going up and down" was this related to anything else (example: did it change with engine RPM, lights on or off, when you use the brakes, and was your A/C on? (2) Is there anything from the stereo system's power supply left in your ride (power caps, noise filters, or anything that uses constant battery power? There are so many questions to ask and answer that if you can't find the trouble I recomend taking it to a professional car audio shop for help. You most likley have a loose ground or power connection somewhere. I DO WANT TO SAY THIS! If your problem would keep you from starting the truck there is a chance that it could also make the engine shut off when being driven so be careful. Good Luck.
