Where is the Starter Relay? 1994 pontiac sunbird
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=59848
Printed Date: April 23, 2026 at 11:00 AM
Topic: Where is the Starter Relay? 1994 pontiac sunbird
Posted By: stupidcar
Subject: Where is the Starter Relay? 1994 pontiac sunbird
Date Posted: July 21, 2005 at 9:23 PM
Where is the starter relay on a 1994 pontiac sunbird? also where is the solenoid switch? Any suggestions on why my car won't start when it is hot outside, or after running idle for several minutes then turned off and restarted?!?
Posted By: w_semken
Date Posted: August 22, 2005 at 12:13 AM
 Doesn,t have a relay, how about the solenoid on the starter. Billy
Billy,s Auto-Again
Posted By: blazeronspokes
Date Posted: August 25, 2005 at 9:43 AM
you might have a bad computer. i had a similar problem with my 87 blazer. i could run the car all day long, but if i shut it off and tried too start it back up it wouldn't. and if it was hot otside(which it is 90%of the time here in florida)it wouldn't start.i finally traced the problem to my faulty computer. 95 bucks from autozone and problem solved. hope this help and good luck.
