using a switch for two things
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=59993
Printed Date: April 23, 2026 at 4:04 PM
Topic: using a switch for two things
Posted By: one04fx4
Subject: using a switch for two things
Date Posted: July 24, 2005 at 6:19 PM
ok. i am using a 528T pulse relay timer. the switch i am trying to use is this. it gets power with the key on and in accessory. but when i go to start the truck it loses power while the key is in start and then returns to power. it is a factory switch. my question is this. if i put diodes inline with it can i use the switch to close a circuit and not have power with it. is this possible.
Posted By: hotwaterwizard
Date Posted: August 27, 2005 at 12:20 AM
You need to explain better if you want help with this. I do not understand exactly what you want to do. You could remove all of the wires and use the switch by it's self.
------------- John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
