Auto Unlock Relay Question
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=60436
Printed Date: April 18, 2026 at 8:57 PM
Topic: Auto Unlock Relay Question
Posted By: todd37
Subject: Auto Unlock Relay Question
Date Posted: July 31, 2005 at 6:46 PM
Hello All,
I just bought a new Ford F150 and the doors lock when you start driving, but when you stop they do not unlock. This is annoying to me since I am used to my GMC unlocking all the doors. I saw the diagram of a relay for this here https://www.the12volt.com/doorlocks/page3.asp#aul but I am confused when looking at the relay wiring diagram. I am pretty savy when it comes to electronics and relay's am I missing something cause there is a positive on both sides of the coil? I went and bought the stuff to make it and it does nothing. If I wire it like the relay on page https://www.the12volt.com/relays/page5.asp#ctm then it does the opposite of what I need. As you all know I need the relay to pulse when the ignition is shut off.
Can anyone can help me with this Please....
Posted By: Hoptup32
Date Posted: July 31, 2005 at 8:11 PM
The https://www.the12volt.com/doorlocks/page3.asp#aul is shown for an ignition switch wire that goes to ground when the ignition switch is turned off.  Relay terminal 85 doesn't ever see 12v from the ignition switch wire because the diode, as shown, is blocking the 12v supply when the switch is on.  When the ignition is turned off, this wire goes to ground and the relay coil is activated, pulsing the required ground thru terminals 30 and 87.
The link below has some helpful wiring info on the 2005 F150
https://www.the12volt.com/installbay/forum_posts.asp?tid=46343
Posted By: todd37
Date Posted: July 31, 2005 at 10:14 PM
The drawing says ignition 12vdc(+) where does the ground come in? Anyway the Ford F150 has a postive when turned on, do you know of another way to accomplish this?
posted_image
Posted By: KPierson
Date Posted: September 23, 2005 at 10:14 PM
[QUOTE=todd37]
Hello All,
[/QUOTE
Try adding a 2nd relay.  On the 2nd relay wire up:
Pin 85 - Ignition (will energize whenever ignition is on)
Pin 86 - Ground ]
Pin 30 - 12dc Ignition signal on the diagram you are using
Pin 87 - Not used
Pin 87A - Ground
With this setup when you turn the vehicle on it will remove the ground from the circuit that allows the relay to pulse.  Once you shut the car off the 2nd relay will drop out, giving the first relay its ground back.
Most ignition systems will rest at ground when the key isn't in, this should probably be noted on the diagram!
Kevin Pierson
Posted By: redpeppers
Date Posted: September 29, 2005 at 12:18 AM
u can prolly turn the feature on in the factory settings...look at the owners manual it may tell u how
Where theres is a wire there's a way.
Posted By: todd37
Date Posted: September 29, 2005 at 8:16 AM
Ford does not offer the auto unlock option only Chevy. You can only turn off the auto lock there is no auto unlock.
