GM Power Windows
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=67040
Printed Date: May 13, 2026 at 9:03 PM
Topic: GM Power Windows
Posted By: qute
Subject: GM Power Windows
Date Posted: November 26, 2005 at 2:28 AM
Hi guys,
I have a 74 Holden (Aussie) ute (think early 70's Chev El Camino) and am putting power windows in it. I have looked through lots of the site, but can't find the answer to my question.
I have an El Camino power window switch in the console and the window motors are the same Delco units as the US 70 - 80 model F bodies use, I believe.
My problem is that the motors do not use reversed polarity for up and down. They have a separate feed for each function and earth through the door/body.
Being a ute (or pick-up) room is at a premuim too. Is there a way to only use 1 relay per window or do I have to use 2?
Thanks...Dave
Cheers...Dave
Posted By: qute
Date Posted: November 26, 2005 at 4:15 AM
I should have mentioned above that I would prefer to have the relays between the switches and motors to minimise the power going through the switches.
Cheers...Dave
Posted By: Mike M2
Date Posted: November 26, 2005 at 7:44 AM
Yes, 2 relays per window. If the switch is anything like a 70's El camino, in reality you could wire them direct using no relays. Back then GM 5 wired the switch directly to the motor, but if you want to minimize the power at the switch, it's 2 relays per door...
Mike M2
Tech Manager
CS Dealer Services
Posted By: qute
Date Posted: November 26, 2005 at 7:50 AM
Thanks Mike, that's what I thought.
I know the switches will handle the current draw, but I like to minimise the amount of "high" power going into and around the cab and wondered if there was an "either/or" relay available that would do the job.
Looks like I'll need to buy a couple more relays and make up an extended mount for them under the dashboard.
Cheers...Dave
