radio on till door open & remote start
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=70680
Printed Date: May 15, 2026 at 9:49 AM
Topic: radio on till door open & remote start
Posted By: mobilecustoms
Subject: radio on till door open & remote start
Date Posted: January 13, 2006 at 1:21 PM
i have the radio on until door opened installed in my 1997 taurus gl and when i remote start the car the radio turn on. When i shut the car off with the remote, the radio stays on. Can this be bypassed to shut off witht he remote starter?
the remote starter is a viper 791xv
Posted By: Hornshockey
Date Posted: January 14, 2006 at 1:25 AM
there should be a wire that pulses after the remote start shuts down. You can use this wire to pulse the doorpin wire on your relay to simulate the door opening. If you have an issue with the alarm going off you can put a diode inline to prevent the pulse from going back to the doorpin in the car.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
Date Posted: January 14, 2006 at 5:38 PM
which wire
maybe factory rearm?
Date Posted: January 14, 2006 at 9:00 PM
fact rearm will work; as long as it pulses after shutdown
