what should i do,Fogs?
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=71585
Printed Date: April 03, 2026 at 1:20 PM
Topic: what should i do,Fogs?
Posted By: aaron19121
Subject: what should i do,Fogs?
Date Posted: January 26, 2006 at 8:46 PM
i have fogs hooked up with a relay and they do cut off when i turn on my high beams. For about one year now i used a 10 and a 15 amp fused near the batt. the problem is after say like 4 months the fuse melts but never blows what can i do to keep this from happening.
Posted By: auex
Date Posted: January 26, 2006 at 9:23 PM
First thing I would recommend would be to check your grounds and make sure that they are good. You should replace the fuse with whatever fuse it came with originally.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
