luishale
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=71952
Printed Date: April 02, 2026 at 11:42 PM
Topic: luishale
Posted By: luis hale
Subject: luishale
Date Posted: February 01, 2006 at 12:34 AM
Hi , Im not  write  english  but, to read little. how make bypass for 350 nissan, with relays? please i need your help in spanish
Posted By: ff-mike
Date Posted: February 01, 2006 at 1:05 PM
Mi español no es ése bueno, sino intenta por favor reposting los detalles de lo que usted necesita en español e intentaré hacer lo que puedo
Posted By: ff-mike
Date Posted: February 09, 2006 at 8:56 AM
Sorry about the caps, too tired to retype...
babel translation of PM from the OP wrote:
HELLO MY PROBLEM IS, AS I CONNECT THE RELAY TO ELIMINATE THE SIGNAL THAT ENVIA THE KEY TO THE IGNITION OF THE CAR? SO THAT WITH THE ALARM THE CAR IF IT IGNITES BUT EXTINGUISHES. I HOPE YOU UNDERSTAND To ME And YOU CAN HELP ME. THANKS
From this and from his opening post I am guessing that he is looking for a bypass similiar to what is used when a VATS system is installed with a remote starter. Not my area of expertise- so I will pass is on here
