5v to 12v
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=75782
Printed Date: March 28, 2026 at 7:33 PM
Topic: 5v to 12v
Posted By: carstereoman
Subject: 5v to 12v
Date Posted: April 06, 2006 at 12:12 PM
Can I use a relay to take in 5 volts and make it 12 volts? I have a lexus with a 5 volt antenna power wire that I need to run 12volts for aftermarket antenna.
Posted By: bigscratch
Date Posted: April 06, 2006 at 3:39 PM
You should be able to find a relay that will work on 5 volts. You will need to find an alternate power supply for the 12 volt circuit since the 5 volts will only be used to actuate the relay.
A look thru the radio shack site indentified a few diffent models that would work for you.
Posted By: ill-logix
Date Posted: April 07, 2006 at 11:55 AM
Is the 5v wire the signal wire going to the antenna or does the antenna actually use 5v dc to operate?  If 5v is the signal use a relay with 5v coil.  Then using the normally opened contacts run +12v from that battery to the new antenna.
Posted By: infinkc
Date Posted: April 12, 2006 at 7:33 PM
use a transistor to a relay
There are 10 types of people in the world, ones that understand binary and ones that dont.
