relays for hydraulics
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7862
Printed Date: May 12, 2026 at 6:48 AM
Topic: relays for hydraulics
Posted By: YOGI
Subject: relays for hydraulics
Date Posted: January 08, 2003 at 9:14 PM
hey everybody i need help wiring an alarm to a hydraulic switch box, so when the alarm is armed it will pancake the car and when disarmed bring car to original position
Posted By: auex
Date Posted: January 08, 2003 at 9:27 PM
I don't know about when arming and disarming but it can be done with other channels of the alarm. I would also need to know what voltage is going through your switch box ( wether a relay would be necessary or if you should use a solienoid). I have done this many times with air solieniods but not with hydrolics.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: themagicone
Date Posted: January 08, 2003 at 9:49 PM
You could use pulse timer set up, have it trigered by the ground when armed output and last for how ever long it takes to put the car down, then wire the factory alarm disarm wire into the same thing to have it come up. Instead of the ground when aremed, you could always you factory alarm arm and disarm from the alarm if it has both of those, or you can use your lock and unlock wires, make sure you diode isolate.
