Keyless Entry--Please help!!!
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=8006
Printed Date: May 12, 2026 at 9:40 AM
Topic: Keyless Entry--Please help!!!
Posted By: punkay11
Subject: Keyless Entry--Please help!!!
Date Posted: January 11, 2003 at 5:19 PM
I was wondering if anyone knows if a 1999 Dodge Stratus has reverse polarity door locks? I am having someone install my remote starter that comes with remote entry and would like to know if I need to purchase an additional T-harness. The starter comes with a relay but I'm not sure if the locks will require additional equipment. Thanks....out in the cold
Posted By: djfearny2
Date Posted: January 11, 2003 at 6:41 PM
now it has a one wire setup that is positive. it is easy to set up i have the same car and it takes a little longer but not to long..
anyways here goes follow this and your 'll be fine.
first of all it is possitive
so set up two relays the same as i am about to state .
set up two negative polarity to possitive pollarity relays using pin 85 as your input from the lock wires of the alarm.
the output wire  from each relay has to have a resistor connected to it the lock requires a possitive pulse through a 620 ohm resistor and unlock requires a possitive pulse relay through a 2.7k ohm resistor to unlock must use relays this wire color is white /green if you meter it you will get the resistance i have told you for each lock and unlock or close but these will work for you it only has to be close to the needed value.  and more help email me personally.
Jon
Installer/Help Technician
---coral springs florida---
Posted By: punkay11
Date Posted: January 12, 2003 at 6:55 AM
Thanks so much, Jon!!! That helps me out COMPLETELY!!!
