Horn trigger & Window mudule ???
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=8179
Printed Date: May 12, 2026 at 1:37 PM
Topic: Horn trigger & Window mudule ???
Posted By: mackadilly
Subject: Horn trigger & Window mudule ???
Date Posted: January 15, 2003 at 1:48 PM
I need assistance on the exact procudure for *6 in my 1999 SAAB
HORN TRIGGER|*6                  |   |steering column
*6 To trigger the horns, use a relay to connect the yellow/white and yellow/black wires at the steering column.
I plan to instal a four window roll module. The diagrams discribes conections to the motor side and window side of 1 cut wire for each window.  Which wire does one cut? Up or down?
LF WINDOW UP/DN|blk/wht - gry/wht   |A  |switch on center console *7 |
|  RF WINDOW UP/DN|blu/wht - grn/gry   |A  |switch on center console *7 |
|  LR WINDOW UP/DN|green - grn/red     |A  |switch on center console *7 |
|  RR WINDOW UP/DN|grn/yel - blu/grn   |A  |switch on center console *7 |
| SUN RF OPN/CLOSE|yellow - yel/blk    |A  |sunroof switch
{{{{(never to old to learn}}}
Posted By: brianh
Date Posted: January 15, 2003 at 4:43 PM
Well it depends if you want to roll them up or down.  If you want to roll them down cut and hook up the down wires to the unit.  Or vise versa.  Good luck.  BrianH
Posted By: Velocity Motors
Date Posted: January 15, 2003 at 6:08 PM
4 window modules will mean that you will have the option to roll up all 4 windows up and down. Each module is capable of rolling 2 windows up or down ( NOT BOTH ). Unless you have bought the up&down modules.
