Constant to momentary?
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=81904
Printed Date: April 19, 2026 at 6:43 AM
Topic: Constant to momentary?
Posted By: debeerd
Subject: Constant to momentary?
Date Posted: August 22, 2006 at 6:24 AM
posted_image
How long does it take for the 10k resistor to bleed off the caps charge ?
Posted By: Velocity Motors
Date Posted: August 22, 2006 at 8:09 AM
You can increase the output time by simply changing the value of the capacitor. This one will give you about a 1/2 second output.
Posted By: debeerd
Date Posted: August 22, 2006 at 1:18 PM
The time is right, I used a 2200uf cap.
But it takes long for the cap to discharge, over 30 seconds.
So when I activate it, I have to wait 30 seconds or so before I can activate it again.
Will changing the resistor do anything ?
Date Posted: August 22, 2006 at 10:25 PM
Lowering the resistance will allow for a faster bleed off time.
Posted By: debeerd
Date Posted: August 23, 2006 at 2:07 AM
I've got some 1k's laying around here somewhere, will give it a try.
Thanks for the helpposted_image
