momentary to constant w/ capacitor
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=85083
Printed Date: May 14, 2026 at 10:25 AM
Topic: momentary to constant w/ capacitor
Posted By: captainzab
Subject: momentary to constant w/ capacitor
Date Posted: November 03, 2006 at 5:35 PM
https://www.the12volt.com/relays/page5.asp#mtc
where would i buy the capacitor need?
also, how would i place the resistor inline with the capacitor?
why does the picture show ground?
am i interpreting this right?
posted_image
yellow thingy is resistor
Note: You Always Dont Get What You Pay For.
Posted By: hotwaterwizard
Date Posted: November 03, 2006 at 6:00 PM
what are you doing? You only need a capacitor if you are going from Constant to Momentary.
posted_image
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
Date Posted: November 03, 2006 at 6:11 PM
Here is an easier diagram of the same thing.
posted_imageposted_image
Stockton California
Date Posted: November 04, 2006 at 8:31 PM
my bad, i meant pulsed to steady, for my turning lights.
how am i suppose do place the resistor?
is my first picture correct?
or do i not need a resistor?
Date Posted: November 04, 2006 at 8:36 PM
Pulsed to Steady Output
If you have cornering lights and want them to come on only when your turn signal is on and you do not have a steady output, use the following for each side. This will give you a steady output while the turn signal is on. Increasing the size of the capacitor will give you a longer output if needed.
posted_image
The Capacitor and Resistor form what is called an RC Network or Resistor Capacitor Network. To put it in easy to understand terms it is a time delay. It holds the voltage for a set period of time causing the circuit to stay on durring the flash period. The capacitor is rather large and can be bought at Mouser Electronics, Digikey, or maybe even Radio Shack.
Stockton California
Date Posted: November 04, 2006 at 8:58 PM
https://www.mouser.com/search/ProductDetail.aspx?R=140-LS103M1H-3530-RCvirtualkey21980000virtualkey140-LS103M1H-3530-RC
Stockton California
Date Posted: November 04, 2006 at 9:06 PM
Why not put an extra  wire on the flaser input instead?
posted_image
Stockton California
Date Posted: November 04, 2006 at 10:49 PM
can i use a smaller capacitor without resistor?
say 1k uf?
i have to use relay, because im useing pulse from turning lignal to turn on the side lights on my bumper. (the lights does not work not, there is no wires going to it)
Date Posted: November 05, 2006 at 12:33 PM
Here is how it works. The capacitor charges up and the resistor bleads off the charge at a certain speed according to the values of each one. If either one is a different size it will drain at a different speed.
So the answer in both cases is NO                                posted_image     and    posted_image
Check out these links to find out more.
https://en.wikipedia.org/wiki/RC_circuit
https://www.antonine-education.co.uk/Electronics_AS/Electronics_Module_1/Topic_10/topic_10__rc_networks_with_dc.htm
Stockton California
