Antenna auto up/down
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=85173
Printed Date: April 02, 2026 at 12:55 PM
Topic: Antenna auto up/down
Posted By: bowez
Subject: Antenna auto up/down
Date Posted: November 05, 2006 at 4:59 PM
Wondering if Momentary to Constant setup is acceptable to actuate a power antenna, upon turning car off? Thinking if had cap/resistor setup to bleed voltage for the time for it go up/down should be just fine (I've timed mine at ~4sec). I'm thinking of using the door switch actually trigger the antenna down (have it go down when open the door with car off) and in my case go up on unlock signal from remote (armed) and actuate on door open.
Posted By: master5
Date Posted: November 05, 2006 at 5:04 PM
You won't need any caps or resistors to do this..diodes and relays at most. However I need to know what kind of vehicle this is (make, model, year) and if the power antenna is factory or aftermarket.
Posted By: bowez
Date Posted: November 05, 2006 at 8:16 PM
93 Ford Tbird OEM.
Posted By: master5
Date Posted: November 05, 2006 at 10:22 PM
ok, I am a little busy at the moment but will check back later and post a diagram if no one else has been able to help.
TTYL
Posted By: master5
Date Posted: November 05, 2006 at 11:40 PM
I need one more piece of info.
Is the factory power antenna fully automatic, or manual (you need to use a switch for up/down)
The reason I ask is that it might not be that simple if it's a fully automatic. whats happens with a fully automatic antenna is that once the "trigger" wire loses power, it goes down,
So if we use any kind of timer or latching relay circuit, the antenna will go down eventually, either when it times out, or once the door is closed. Perhaps I can design a circuit that can also kill the main power to the antenna motor once it's up, then reactivate it for down.
But before I rack my brain on that one, if it is a manual power antenna, or if you purchase one (they are not expensive, I can use a latching relay circuit along with a reverse polarity and it should work.
Posted By: master5
Date Posted: November 05, 2006 at 11:58 PM
I thought of an idea. If it is a fully auto antenna (which it should be) try this. How it works is when you unlock the car with the remote..the antenna will go up.  Lock car with remote...the antenna goes down. Let me know if this will work for you.
Posted By: bowez
Date Posted: November 06, 2006 at 5:37 PM
Is not fully auto, you must hold button for it to go up or down just like a window.
