indicators to relay
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=87332
Printed Date: May 13, 2026 at 10:16 AM
Topic: indicators to relay
Posted By: shaun leong
Subject: indicators to relay
Date Posted: December 17, 2006 at 1:08 AM
Hi all
Somebody might be able to help here, im rewiring my beach buggy and want to connect my indicators to a relay. I have read the forum on this site and have found a lot information.  Do I wire my indicators as per a wigwag or is there more simpler way of doing it with just one relay . in total I have 174watts of power and have wired the Hazards straight to the battery on a switch.
I await your reply.
Shaun
PS. this is one of the best sites that I have come across
dk2400
Posted By: hotwaterwizard
Date Posted: December 19, 2006 at 8:46 AM
Explain better.
I think you want to hook some Indicator lights up so you can see when  the Wigwag circuit is on???
posted_image
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
Date Posted: December 20, 2006 at 7:51 PM
Hi
No im running three 21w lights each side of the car two 3w lights on the dash board. Totaling 174w. Do i need to run them into a relay if so how do i do this.
thanks Shaun
dk2400
Date Posted: December 20, 2006 at 9:30 PM
posted_image
Stockton California
Date Posted: December 20, 2006 at 9:51 PM
If the lights already work and Wig-wag, just hook the wires in parallel with the existing lights on each side and to the dash lights .
posted_image
Stockton California
