relays on speakers?
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=88994
Printed Date: April 23, 2026 at 9:30 AM
Topic: relays on speakers?
Posted By: joey2714
Subject: relays on speakers?
Date Posted: January 15, 2007 at 1:51 PM
ok i am going to have a bunch of speakers on a t15004 amp. say i want to only play some of them, since they're on the same amp, is there anyway that switches can interupt the speakers from getting power? relays or anything?
------------- Pioneer Avic D3
Rockford Fosgate T15004
Rockford Fosgate T20001BD x 2
15" Fully Loaded Fi BTL x 2
6" Eminence Alpha Mids x 16
Eminence APT-80 Tweeters x 16
260 Amp Iraggi alt
Kinetik 2400 x 3
Posted By: Big Dog
Date Posted: January 15, 2007 at 2:08 PM
Study this page, especially near the bottom https://www.the12volt.com/relays/page5.asp------------- Prepare your future. It wasn't the lack of stones that killed the stone age.
Posted By: joey2714
Date Posted: January 15, 2007 at 3:38 PM
that confused the s*** out of me. lol. ill study it some more, so its possible? i figured that i can just have a basic on/off switch inline on each speakers positive lead, but then how to turn them all on or off at once?
260 Amp Iraggi alt
Kinetik 2400 x 3
Posted By: Big Dog
Date Posted: January 15, 2007 at 4:02 PM
Use a standard Bosch type relay.
You can put one of the two speaker leads through the relay connected to pins 30 and 87a. Then, pin 86 to positive 12V. Pin 85 gets a ground via a switch.
In this way turning the switch ON will CUT that speaker.
Whatever speakers you want cut at once, connect the pin 85 of that particular relay to the switch.
You can have more than one relay on the switch.
Watch out for impedance.
Posted By: joey2714
Date Posted: January 15, 2007 at 4:09 PM
what do you mean by watch out for the impedence? that changes through relays and switches? sorry for all the questions, i've never done relays before and i dont wanna screw anything up
260 Amp Iraggi alt
Kinetik 2400 x 3
Posted By: Big Dog
Date Posted: January 15, 2007 at 6:43 PM
Impedance might not be an issue but, because I don't have details about what you plan to do, I thought I'd alert you in case.
For example, you can't put four speakers in parallel neither can you short the outputs for obvious reasons.
Posted By: joey2714
Date Posted: January 15, 2007 at 7:45 PM
woah, i cant have 4 speakers in parallel? i have four 8 ohm speakers, was going to wire them parallel to show the amp 2 ohms. can that still be done with relays? again.. i know nothing about them so thanks for the help bigdog
260 Amp Iraggi alt
Kinetik 2400 x 3
Posted By: Big Dog
Date Posted: January 16, 2007 at 7:49 AM
Never mind what I said - just observe impedance as per the amps manufacturers suggestion.
