second starter relay
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=91789
Printed Date: March 22, 2026 at 3:00 PM
Topic: second starter relay
Posted By: oapy123
Subject: second starter relay
Date Posted: March 16, 2007 at 5:30 PM
ok i've been out of the game for a while and i'm a little fuzzy on relays...and today i am installed a DEI remote start/keyless entry unit on a 97 nissan pathfinder
got everything hooked up fine, it all works but i want to go ahead and power the second starter wire so he doesnt have trouble if it gets cold or whatever...i just need to know which pins go to what
i think it is
85 trigger from brain (negative output when remote started)
86 12v
30 12v
87 output (second starter wire)
is this right?
how would I do it with a 451M?? (yes i know its for doorlocks but i remember using it a few times for second starter when i didnt have any regular relays)
small green wire in 3-wire plug - trigger from brain(ground when started)
large green wire - output (second starter wire)
purple - 12v
white - 12v
thanks for any help
2 L7's
1 JBL 1200.1
Knu Konceptz wiring
Second Skin sound dampening
Posted By: Velocity Motors
Date Posted: March 16, 2007 at 8:14 PM
Use this diagram for the 2nd STARTER . If you use one that you stated in your post it will give the 2nd starter wire a continuous 12 volts for the duration of the remote start sequence.
