am i using the right relay setup
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=94232
Printed Date: May 08, 2026 at 12:32 AM
Topic: am i using the right relay setup
Posted By: ripdis85
Subject: am i using the right relay setup
Date Posted: May 25, 2007 at 4:44 AM
Hey,
I'm looking at installing 4 headrest monitors. I would like them to power up once I turn on my dvd head unit. I just wanted to confirm this with someone.
By the looks of this diagram this should give constant power to the screens once the HU is turned on. Am I wrong to say that the power for the screens comes off of the 12V and not the remote wire and the remote wire is just used to "power on" the relay right?
posted_image
Thanks for the help
Posted By: wlmpwlmp
Date Posted: May 25, 2007 at 4:52 AM
Wiring the relay as the pic shows will serve your needs well. As to your question, i would say you are using the relay to power the tvs, the trigger is only activating that relay.
WesMan
Posted By: ripdis85
Date Posted: May 25, 2007 at 9:02 PM
thanks for the helpposted_image
