latching relay
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=95876
Printed Date: May 06, 2026 at 9:37 PM
Topic: latching relay
Posted By: rtm038
Subject: latching relay
Date Posted: July 24, 2007 at 2:13 PM
Hello,
I need a 12+VDC latching relay that'll do the following:
1. 1st 12+VDC pulse= latch
2. 2nd 12+VDC pulse= unlatch
3. Power loss= unlatch
Ryan
Posted By: ranger svo
Date Posted: July 24, 2007 at 7:54 PM
You need two relays. The first will be the latch relay, the second will shut it downposted_image
The moving power of mathematical invention is not reasoning but imagination.
Augustus de Morgan
Posted By: randyre
Date Posted: July 25, 2007 at 1:56 PM
So how would you go about making the first pulse latch power on, the second activate a second relay monetary on, and the third pulse turn them all back off, and the fourth pulse start thesequence again??
Posted By: hotwaterwizard
Date Posted: July 26, 2007 at 8:36 AM
That would be a complicated mind boggling circuit.
A Digital circuit would be required.
You could just buy a 4 channel remote to do the job.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
Posted By: randyre
Date Posted: July 26, 2007 at 2:01 PM
Well if you say that, I'm betting thats a pretty definitive answer :)  How would a remote do this? i already have a remote start installed and would be hooking into this.
Posted By: randyre
Date Posted: July 26, 2007 at 2:04 PM
So I'm also guessing this is impossiblem since its nearly the same thing.
https://www.the12volt.com/installbay/forum_posts.asp~TID~95849~PN~1
