can a spdt be used in place of an spst?
Forum Name: Relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98635
Printed Date: March 21, 2026 at 8:41 AM
Topic: can a spdt be used in place of an spst?
Posted By: 91mx5
Subject: can a spdt be used in place of an spst?
Date Posted: November 04, 2007 at 10:29 PM
I'm installing a high-draw horn and bought the wrong relay. Was supposed to be a SPST. Can I just leave the 87a blade unconnected and assume it will function as an SPST?
Thanks.
Posted By: techman93
Date Posted: November 05, 2007 at 6:28 AM
You can use the relay without that terminal connected. It doesn't make a big difference it will work for what you need it for.
Posted By: becks2055
Date Posted: November 07, 2007 at 2:02 AM
yes you can
