How about a search?
Forum Name: New Ideas for the12volt.com
Forum Discription: Tells us what you'd like to see on the12volt.com.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=16056
Printed Date: May 11, 2026 at 10:24 AM
Topic: How about a search?
Posted By: csorrows
Subject: How about a search?
Date Posted: July 08, 2003 at 3:38 PM
When you do a search in the installer database for an entire state (search blank but select state and country from pull down menus) you get the whole country!:o): It seams to me the code should give all the results for a state if selected in the pull down but it ignores it.:x
------------- You can build anything if you have enough time and patience!
Posted By: the12volt
Date Posted: July 08, 2003 at 3:54 PM
If you select a country, you will get all results from the chosen country as well as the selected state. Try just selecting the state and leaving everything else blank. Here's a search just for Texas: https://www.the12volt.com/installbay/findinstaller.asp?search=yes&City=&state=Texas&country=&Submit=Search------------- the12volt • Support the12volt.com
Posted By: csorrows
Date Posted: July 10, 2003 at 1:56 AM
Well that would make to much sense I guess. *thinks of getting more sleep* Nah, too much to do to sleep. Anyways, Thanks!
Posted By: DM4CA
Date Posted: July 15, 2003 at 9:14 AM
I'm looking for a particular product in the Buy/Sell forum. I get EVERY mention of the product on all forums with no indication what forum the post was in, so I have to read them all.
The Search function here is seriously weak!
Date Posted: July 15, 2003 at 9:26 AM
If you are looking for a particular product in the Buy and Sell forum, you can limit your search just to that forum in the drop down menu provided here: https://www.the12volt.com/installbay/search_form.asp . If you are only searching from this page, then your results will include all forums. ------------- the12volt • Support the12volt.com
Posted By: DM4CA
Date Posted: July 15, 2003 at 9:34 AM
Okay, how do I get to
via
https://www.the12volt.com/installbay/search.asp
Date Posted: July 15, 2003 at 9:43 AM
Date Posted: July 15, 2003 at 9:45 AM
Posted By: cpgoose
Date Posted: July 15, 2003 at 10:49 AM
 Good job 12volt, keep up the good work!  ------------- Q: What's the best nation in the world?
A: Donation! Donate to the12volt.com
Date Posted: July 16, 2003 at 7:51 AM
Thanks cpgoose ;) ------------- the12volt • Support the12volt.com
