2002 bonneville remote start diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100325
Printed Date: May 13, 2026 at 11:10 PM
Topic: 2002 bonneville remote start diagram
Posted By: eng1
Subject: 2002 bonneville remote start diagram
Date Posted: December 22, 2007 at 7:30 PM
just wondering if a 2002 wiring diagrams for remote start are the same as a 01 bonneville if not could use the 2002 thanks
Posted By: KarTuneMan
Date Posted: December 23, 2007 at 10:34 PM
PASSIVE ANTI-THEFT YES TRANSPONDER   SEE NOTES
 12 VOLTS Red at battery or behind fusepanel   +
 It is recommended that you find an alternate power source than the one from the ignition switch since this wire is a very small gauge.
 IGNITION Pink Ignition switch   +
 These wires are all small gauge but can be connected normally.
 IGNITION 2 White Ignition switch   +
 ACCESSORY Orange Ignition switch   +
 STARTER Yellow Ignition switch   +
 KEY SENSE Lt.green Ignition switch   -
 TACH SIGNAL White At coil pack on right side of engine   AC
 LOCK RED / black At switch in driver's door   -
 This is a multiplex doorlock system. You must run wires into the driver's door to interface the doorlocks.
 UNLOCK ORANGE / black At switch in driver's door   -
 DRIVER LOCK MOTOR Gray In driver's door at switch   +
 DRIVER UNLOCK MOTOR Tan In driver's door at switch   +
 PASSENGER UNLOCK MOTOR Tan In passenger door at switch   +
 DOORPIN BLACK/ white In each individual door   -
 DRIVER DOOR LATCH Tan 8-pin plug on driver's door module   -
 This is a multiplex system. You must go into the driver's door to interface these wires. Pulse a ground (-) to the TAN wire at the same time as lock to arm the factory alarm, diode isolate.
 FACTORY ARM Tan 8-pin plug on driver's door module   -
 FACTORY DISARM Lt.green 8-pin plug on driver's door module   -
 BRAKESWITCH White At switch above brake pedal   +
 PARKLIGHTS BROWN / white At light switch harness   -
 HORN Black At steering column   -
