05 pontiac pursuit
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101827
Printed Date: April 19, 2026 at 4:44 PM
Topic: 05 pontiac pursuit
Posted By: red85
Subject: 05 pontiac pursuit
Date Posted: February 03, 2008 at 8:52 AM
I have a rs install on an 05 Pontiac Pursuit to do and I'm wondering if anyone has the wiring for this car.  Is there anything tricky about this car that I should be aware of?  I will be using an iDatalink ADS TBSL PL bypass on this install.
Posted By: KarTuneMan
Date Posted: February 03, 2008 at 7:38 PM
12 VOLTS RED / black C3 plug on BCM in center console   +
 The BCM is located in the passenger side of the center console. It has 4 plug running left to right C1 (72-pin), C2(72-pin), C3(40-pin) & C4 (not used).
 IGNITION Yellow Ignition switch harness or C4 plug on BCM   +
 ACCESSORY Brown Ignition switch harness or C4 plug on BCM   +
 STARTER SEE NOTES
 No connection is required for remote start. When accessory shuts down during the start cycle the vehicle will crank automatically.
 TACH SIGNAL Use an injector wire
 FUEL INJECTOR Opposite from Pink At any injector on engine   AC
 LOCK White In driver's kickpanel or C1 plug on BCM   -
 1-wire system. Ground (-) to lock and ground through 1.5K resistor to unlock. The BCM is located in the passenger side of the center console. It has 4 plug running left to right C1 (72-pin), C2(72-pin), C3(40-pin) & C4 (not used).
 UNLOCK White In driver's kickpanel or C1 plug on BCM   -
 DOORPIN SEE NOTES
 Driver's door (Gray/black) and Passenger door (Tan/white) are both found at the BCM on the passernerg side of the center console in the C1 (72-pin plug).
 TRUNK PIN ORANGE / black C1 plug on BCM in center console   -
 TRUNK RELEASE Tan C2 plug on BCM in center console   -
 FACTORY ARM With OEM remote only
 FACTORY DISARM With OEM remote only
 BRAKESWITCH Lt.blue At switch above brake pedal   +
 PARKLIGHTS Brown In driver's kickpanel or C1 plug on BCM   +
 HAND BRAKE Lt.blue C1 plug on BCM in center console   -
 HORN Tan Ignition switch or C2 plug on BCM   -
 CLUTCH SWITCH Yellow At clutch switch   Type 1
 REVERSE LIGHTS Lt.green Under driver's side running board   +
 PASSLOCK DATA White Ignition switch harness   DATA
 PASSLOCK GROUND WHITE/ black Ignition switch harness   -
