2005 honda element ex remote start pkh34
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=104812
Printed Date: March 30, 2026 at 6:35 AM
Topic: 2005 honda element ex remote start pkh34
Posted By: deneteus
Subject: 2005 honda element ex remote start pkh34
Date Posted: May 18, 2008 at 5:14 AM
Does anyone have the wiring diagrams for a 2005 Honda Element EX?
I am planning to use the PKH34 and also the door lock bypass with the XK02 with HODL firmware.
Posted By: Velocity Motors
Date Posted: May 18, 2008 at 7:45 AM
HONDA » ELEMENT » 2005
ITEM      WIRE COLOR      POL      LOCATION      INFOTECH #
12 VOLTS      white (50a)      +      ignition harness
     Notes: The factory alarm plug is a green plug to the left of the steering column.
STARTER 1      BLACK/ white      +      ignition harness
STARTER 2      n/a
IGNITION 1      BLACK / YELLOW      +      ignition harness
IGNITION 2      n/a
IGNITION 3      n/a
ACCESSORY 1      BLACK/ red      +      ignition harness
ACCESSORY 2      WHITE/ red      +      ignition harness
KEYSENSE      RED / white      -      ign harn or factory alarm plug
DATA BUS
POWER LOCK      WHITE/ blue      -      driver kick, door harness
POWER UNLOCK      WHITE/ green      -      driver kick, door harness
DOORLOCK MOTOR      yellow/black      5wi      dkp or back of fuse box, top left
DOOR UNLOCK MOTOR      YELLOW /GREEN      5wi      dkp or back of fuse box, top left
DISARM NO UNLOCK      factory remote only
FACTORY ALARM ARM      factory remote only
FACTORY ALARM DISARM      factory remote only
DISARM DEFEAT
PARKLIGHTS POSITIVE      RED / black      +      back of fuse box, top middle
     Notes: Can also use RED / yellow (+) at the front of the fuse box, 18 pin plug, pin 15.
PARKLIGHTS NEGATIVE      blue      -      switch or factory alarm plug
HEADLIGHT      blue/red      -      switch or factory alarm plug
HAZARD      same as turn signal wires
TURN LEFT      GREEN/ red      +      turn signal switch
TURN RIGHT      GREEN/ YELLOW      +      turn signal switch
REVERSE      GREEN/ black      +      frt of fuse box, 18 pin plug, pin 1
BRAKE      WHITE/ black      +      brake pedal switch
PARKBRAKE      GREEN/ orange      -      immobilizer control unit, pin 4
     Notes: The Immobilizer Control Unit is on the ignition key cylinder.
DOOR PIN      green (d), gray/black (p)      -      frt of fusebox or factory alarm plug
     Notes: Use both wires and diode isolate each.
HOOD PIN      n/a
TRUNK PIN      red      -      frt of fusebox or factory alarm plug
DOMELIGHT SUPERVISION      GREEN/ red      -      back of fuse box, top right
TACH      blue      ac      ecm/pcm behind glovebox, pin e25
VSS      blue/white            ecm/pcm behind glovebox, pin e26
GLOW PLUGS      n/a
CLUTCH
TRUNK RELEASE      n/a
SLIDEDOORS      n/a
LEFT FRONT UP/DWN      RED / black - RED / yellow      A      driver window switch in door
RIGHT FRONT UP/DWN      blue/red - blue/white      A      driver kick, door harness
LEFT REAR UP/DWN      n/a
RIGHT REAR UP/DWN      n/a
SUNROOF LIMIT      n/a
SUNROOF OPEN/CLOSE      n/a
MEMORY SEAT 1      n/a
MEMORY SEAT 2      n/a
MEMORY SEAT 3      n/a
HORN      orange      -      switch or factory alarm plug
DEFROST
WIPER      blue (l), blue / YELLOW (h)      -      windshield wiper switch
RADIO 12V      WHITE/ red      +      radio harness
RADIO GROUND      black      -      radio harness
RADIO SWITCH      yellow/red      +      radio harness
RADIO ILLUMINATION      RED / black      +      radio harness
FACTORY AMP TURN ON      same as power antenna wire
POWER ANTENNA      YELLOW /GREEN      +      radio harness
LEFT FRONT SPEAKER      GREEN/ black - green      +,-      radio harness or amp in pass. kick
RIGHT FRONT SPEAKER      GREEN/ YELLOW - blue / YELLOW      +,-      radio harness or amp in pass. kick
LEFT REAR SPEAKER      blue/white - blue/black      +,-      radio harness or amp in pass. kick
RIGHT REAR SPEAKER      pink - blue / YELLOW      +,-      radio harness or amp in pass. kick
Posted By: deneteus
Date Posted: May 18, 2008 at 1:47 PM
thank you very much!
Posted By: bbullers
Date Posted: May 19, 2008 at 12:25 PM
You can also check, https://bulldogsecurity.com and click on Vehicle Wiring Diagrams, although what is above should be perfect., but the more info, the better
The Only Stupid Question, is the one Un-asked
