remote turn on wire, 08 dakota
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=105887
Printed Date: March 29, 2026 at 11:57 PM
Topic: remote turn on wire, 08 dakota
Posted By: stonecoldjer
Subject: remote turn on wire, 08 dakota
Date Posted: July 03, 2008 at 12:16 AM
I have a 2008 Dodge Dakota. I have everything I need to hook up an aftermarket stereo. I am going to use the stock deck and I don't know which wires are the speaker wires and which wire is the remote turn on or amp turn on. Is there a adapter needed or what? If anyone knows a site for free wiring diagrams for my model or can e-mail some info on this, that would be great
Posted By: Velocity Motors
Date Posted: July 03, 2008 at 9:23 AM
New o8 Dakota's use the CANBUS to turn on the amplifiers. If you want a remote turn on you will need to use the switched ignition/acccessory wire from the ignition switch or the fuse panel.
Date Posted: July 03, 2008 at 3:35 PM
Thanks for the help. A quick question. Would I be able to use the 12 volt switched power wire as my amp turn on instead of the ignition. It comes on when the key is turned back?????
Date Posted: July 04, 2008 at 12:22 PM
Yes, use the ACCESSORY power if you want to.
