1994 silverado steering column wirres
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=106242
Printed Date: May 13, 2026 at 3:34 AM
Topic: 1994 silverado steering column wirres
Posted By: richerie
Subject: 1994 silverado steering column wirres
Date Posted: July 19, 2008 at 8:25 PM
I am using 94 silverado, 4.3L, auto, steering column in street rod. Any help in deciphering column wires would be greatly appreciated.
Rich in Erie
Posted By: i am an idiot
Date Posted: July 19, 2008 at 8:49 PM
| 1994 Chevrolet C/K Pickup Alarm, Remote Starter, Keyless Entry Wiring Information | | Constant 12V+ | Red | Ignition Switch Harness | | Starter | Purple | Ignition Switch Harness | | Ignition | Pink | Ignition Switch Harness | | Accessory | Orange | Ignition Switch Harness |
The above are the wires on the ignition switch. How many other wires are there in the other harnesses? Are you willing to do a little footwork tracing the other wires to let me know where they go?
Posted By: richerie
Date Posted: July 20, 2008 at 7:32 AM
Thanks, I got the wire clips and here are the color assignments. There is an 11 position clip containing the following wires and assigned to specific alphabetic positions: position D: na positon E: tan position F: Lt green position G: black position H: Lt blue (double) position J: Dk blue (double) position K: brown position L: purple position M: yellow position N: Dk green position P: white There is also a 5 position clip having the following alphabet assignment: position A: na position B: pink (shunted to position "F") position C: purple position D: white position E: grey position F: pink (shunted to position "B") position G: na -------------
Rich in Erie
Date Posted: July 20, 2008 at 10:08 AM
What controls are on the column? Blinkers, cruise control, horn, hi-lo beam switch? You may need to let me know which wires go to which of the switches.
Posted By: richerie
Date Posted: July 20, 2008 at 11:58 AM
Wel, as far as I can tell it contains: horn, wiper motor with intermittent, mist and washer, hi-lo and the ignition. The color code you gave me is not what I have directy on the column. The major column switch has 4 wires: large yellow (starter?), pink, red and brown. Also, a 3 wire switch contains red, orange and green (smaller of the 3 wires). Any help?
Rich in Erie
Date Posted: July 20, 2008 at 12:51 PM
On the major switch the larger wire is probably the constant wire that feeds the switch. To find this out you will need to get an ohm meter and put it to the diode test function. Following is a symbol for a diode.
Attach one lead to the larger wire and turn the key to the accessory position. Touch the other lead to the remaining 3 wires (one at a time). One of these wires should make your meter beep at you. Turn key off and it should quit beeping. Label this wire as Accessory. Turn the key to the run position, touch the lead to each of the 2 remaining wires, the one that makes the meter beep is Ignition. Attach the lead to the remaining wire and turn key to start position, if it beeps label it as starter wire.
