odd door lock issue 05 silverado
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=107264
Printed Date: April 09, 2026 at 7:53 AM
Topic: odd door lock issue 05 silverado
Posted By: ExactOh
Subject: odd door lock issue 05 silverado
Date Posted: September 06, 2008 at 8:34 PM
I just purchased an '05 Silverado.  I used to install remote starters, but have been out-of-it for about three years.  This truck has a AutoPage RS-900 starter, and a DEI 1700G passlock bypass/door lock module in it as purchased.
The problem I have is when unlocking the truck with either the remote, or even using the factory door unlock button, the rear doors do not unlock.  Both of the front doors work as expected, with both the remote and door button, along with when you put the vehicle in drive/park, etc.
I checked all of the door lock wiring, from the 1700G, to the RS900, etc., and all seems to be fine.  I also looked at all of the programming options in the owner's manual for the truck, and both of the units listed above to see if you could program this anomaly to occur.  I also checked the two wires from the BCM that regulate unlocking the rear doors, from the purple connector, and they are intact (at least to the kick panel).
Does anyone know of any programming option that would disable the rear door unlock function with this vehicle's BCM, or with either of these aftermarket units?
If anyone has any suggestions, it would be appreciated.  Thanks.
KLS Glass Tinting & Electronics
Posted By: INSTALLER_MSS
Date Posted: September 12, 2008 at 11:25 PM
take the rear door panels off and see if they are missing, not getting power, disconnected, etc.  if you they are still there and they are getting power and ground, they are bad and need to be replaced.  if they are missing, obviously they need to be replaced.  if they are not getting power and/or ground, trace backwards to the bcm and relays.  check the wiring in the door, boot in the jamb, molex plugs, etc.  there isn't programming that can disengage rear doors in that truck.  the only options for lock/unlock in the module is driver priority locks (drivers door unlocks with first press of button, then all others with second) or all doors unlock simultaneously.
"If a man made it, another can modify it...it just takes some thinking."
"If you ask questions, you're a fool for 5 minutes; if you don't, you're a fool for a lifetime."
Posted By: megaman
Date Posted: September 13, 2008 at 9:24 AM
If your rear doors do not unlock with the door switch then it's not a programming issue.
Posted By: ExactOh
Date Posted: September 17, 2008 at 1:18 PM
Thank you two for the replies.
I had the left side door panel off, and all seems normal in the door.  I checked here first, before getting out the multimeter though.  I guess since there are no programming options, that will be the next step.
I just found it odd that the back doors don't have a problem locking with the switch or when the truck is put into gear, but never will they unlock.  It ticks me off sometimes, especially since the system has been changed quite a bit by an aftermarket alarm/remote start/keyless entry system... you'd think it should work better than factory!
Thanks again.  I will post back someday when I find the problem.
