vss and reverse wire 07 tundra cm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=107554
Printed Date: April 07, 2026 at 7:14 PM
Topic: vss and reverse wire 07 tundra cm
Posted By: jman1113
Subject: vss and reverse wire 07 tundra cm
Date Posted: September 19, 2008 at 7:48 PM
Hi, I have a 07 Toyota, Tundra Crewmax SR5 with the stock 6 disc changer  I changed it out for an AVIC Z3 and need loc and color for the vss and reverse wires for the nav and camera to work properly. I haven't found any reliable info on these.   Thought the extra stock harness would have the vss since it has speed control If you can help, I'd appreciate it.  Thanks
hi
Posted By: i am an idiot
Date Posted: September 19, 2008 at 7:56 PM
posted_imageSpeed SenseYELLOW(AC)AT SKID CONTROL ECU AT BRAKE BOOSTERposted_image
posted_imageParking LightsORANGE(-)AT COLUMN
posted_imageLow Crr. Pk LightsORANGE (-)AT VEHICLE LIGHT SWITCH
posted_imageBrake LightsORANGE(+)AT SWITCH ABOVE BRAKE PEDAL
posted_imageReverse LightsBLUE(+)IN HARNESS IN DRIVERS KICKPANEL
