2002 lexus es 300 alarm,rs, heated seats
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=108710
Printed Date: April 01, 2026 at 6:44 PM
Topic: 2002 lexus es 300 alarm,rs, heated seats
Posted By: jcran17
Subject: 2002 lexus es 300 alarm,rs, heated seats
Date Posted: November 06, 2008 at 1:00 PM
I am going to install a viper 571xv with 555xw in a 2002 ES300 and can't find the wiring diagram anywhere. I was also thinking of powering the heated seats at start-up. Thanks for the help
Posted By: ckeeler
Date Posted: November 06, 2008 at 2:53 PM
| 12 VOLT CONSTANT | WHITE/ RED (+) | IGNITION SWITCH HARNESS | | | STARTER | BLACK/ WHITE (+) Must use BOTH Starter | IGNITION SWITCH HARNESS | | | STARTER 2 | GREEN/ YELLOW (+) wires for Remote Starting!!! | IGNITION SWITCH HARNESS | | | IGNITION 1 | BLACK/ RED (+) | IGNITION SWITCH HARNESS | | | IGNITION 2 | BLACK / YELLOW (+) | IGNITION SWITCH HARNESS | | | IGNITION 3 | N/A | | | | ACCESSORY /HEATER BLOWER 1 | BLUE (+) | IGNITION SWITCH HARNESS | | | ACCESSORY /HEATER BLOWER 2 | N/A | | | | KEYSENSE | N/A | | | | PARKING LIGHTS ( - ) | RED (-) | @ HEADLIGHT SWITCH | | | PARKING LIGHTS ( + ) | GREEN (+) | @ BOTTOM OF FUSEBOX | | | POWER LOCK | BLUE / YELLOW (TYPE B) | @ DRIVERS DOOR MODULE in DRIVERS DOOR | | | POWER UNLOCK | BLUE (TYPE B) REQUIRES DOUBLE PULSE | @ DRIVERS DOOR MODULE in DRIVERS DOOR | | | LOCK MOTOR WIRE | BLUE/RED (+) | IN DRIVERS KICK, at DOOR HARNESS | | | DOOR TRIGGER | See NOTE * 1 | | | | DOMELIGHT SUPERVISION | TURNS ON with UNLOCK | | | | TRUNK RELEASE | WHITE/ BLUE (5-WIRE) Requires Relay | IN DRIVERS KICK PANEL | | | SLIDING POWER DOOR | N/A | | | | HORN | GREEN/ BLACK (-) | @ STEERING COLUMN HARNESS | | | TACH | BLACK/ ORANGE See NOTE *2 | PIN 5 @ 31 PIN PLUG AT ECM See NOTE *2 | | | WAIT TO START LIGHT | N/A | | | | BRAKE | GREEN / WHITE (+) | @ SWITCH ABOVE BRAKE PEDAL | | | FACTORY ALARM DISARM | N/A | | | | ANTI-THEFT | TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES BYPASS MODULE | TRANSPONDER @ IGNITION SWITCH TUMBLER | |
| NOTES | NOTE *1 THE DRIVERS DOOR TRIGGER IS RED / GREEN (-) LOWER LEFT OF THE FUSEBOX.THE PASSENGER DOOR IS RED / GREEN (-) AT UPPER LEFT OF THE FUSEBOX.THE LEFT REAR DOOR TRIGGER IS RED / WHITE (-) ,AND THE RIGHT REAR IS RED / YELLOW (-) AT AT BOTTOM OF FUSEBOX. WHEN CONNECTING TO AN ALARM SYSTEM, USE ALL 4 WIRES AND DIODE ISOLATE EACH, SEE DIAGRAM.
NOTE *2 THE ECM IS BEHIND THE GLOVEBOX. |
