2004 buick century wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=110533
Printed Date: May 13, 2026 at 1:41 AM
Topic: 2004 buick century wiring
Posted By: sandrelli
Subject: 2004 buick century wiring
Date Posted: January 10, 2009 at 8:41 PM
Hi. I need a wiring diagram for a 2004 Buick Century. Will be installing a Taxi Meter into this vehicle, so I definitely need VSS info. Any and all help much appreciated!
Posted By: i am an idiot
Date Posted: January 10, 2009 at 9:34 PM
| WIRE | | COLOR | | POLARITY | | LOCATION | |  |  | Battery | | RED | | (+) | | IGNITION SWITCH HARNESS | | |  | Ignition 1 | | PINK | | (+) | | IGNITION SWITCH HARNESS | | |  | Ignition 2 | | WHITE | | (+) | | IGNITION SWITCH HARNESS | | |  | Ignition 3 | | ORANGE | | (+) | | IGNITION SWITCH HARNESS | | |  | Accessory 1 | | BROWN | | (+) | | IGNITION SWITCH HARNESS | | |  | Starter 1 | | YELLOW | | (+) | | IGNITION SWITCH HARNESS | | |  | Anti-Theft Type | | GM PASSKEY III ANTI-THEFT SYSTEM | | |  | Anti-Theft Descript | | TRANSPONDER | | |  | Key Sense | | LIGHT GREEN | | (-) | | IGNITION SWITCH HARNESS | | |  | Neutral Safety | | YELLOW | | (-) | | IN HARNESS TO TRANSMISSION | | |  | Tachometer | | WHITE | | (-) | | AT IGNITION COIL | | |  | Crankshaft Sensor | | LIGHT BLUE/BLACK | | (-) | | AT PCM MODULE BEHIND THE DRIVERS SIDE HEADLIGHT UNDER HOOD | |  |  | Camshaft Sensor | | BROWN / WHITE | | (-) | | AT PCM MODULE BEHIND THE DRIVERS SIDE HEADLIGHT UNDER HOOD | |  |  | Speed Sense | | DK.GREEN / WHITE | | (AC) | | AT CRUISE CONTROL ON PASSENGER'S SHOCK TOWER |
Date Posted: January 10, 2009 at 11:44 PM
Thank you very much for the quick response. Happy new year!
