nissan bluebird u13 diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113154
Printed Date: April 28, 2026 at 5:43 AM
Topic: nissan bluebird u13 diagram
Posted By: bpshirley
Subject: nissan bluebird u13 diagram
Date Posted: April 14, 2009 at 7:47 PM
Hi there could someone please give me a link to a diagram for installing an alarm in my 1996 nissan bluebird u13?
Posted By: howie ll
Date Posted: April 15, 2009 at 6:09 AM
Look up Nissan Altima from that year on the vehicle wiring chart here, or UK Primera on Directecwire, it's the nearest you will get, it's what I'd do and then test. If your experienced it shouldn't be any problem. If pressing the lock switch on the door doesn't do the driver's door you will need an actuator for that door.
Posted By: t&t tech
Date Posted: April 26, 2009 at 3:32 PM
top of my head, ignition BLACK/ red, only ignition cut is required for immobiliser here as it also prevents the starter from cranking, park lights- RED / blue, driver floor loom, door switch-RED / white, driver floor loom, 12 volts- white ignition harness, i think, actuator required for driver door, lock trigger- grey, unlock-purple, at loom leading into driver door, oem wires for actuator can be found in driver's floor loom, two thick gauge wires, can't remmember off hand the colours, you can tap your after market actuator wires to these, so the rocker switch will control all four doors, gas wire - thick gauge BLACK / YELLOW driver floor loom, indicators-GREEN/ black, GREEN/ YELLOW, driver floor loom.
