audi ignition wire diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113358
Printed Date: May 15, 2026 at 12:57 PM
Topic: audi ignition wire diagram
Posted By: p4u1c
Subject: audi ignition wire diagram
Date Posted: April 23, 2009 at 6:28 AM
Hi Guys, im new to this site and what i see so far i will be on hear alot its mad, if you can help im fitting a remote start alarm and have to fit some wires to the ignition but i cant find a wire diagram for my car, i need to no what each couler wire is for i.e acc - what couler wire, str - what couler, on - acc same again i need to no what couler wire is, i have a 1996 audi a3 and would apreciate any help, i also need to no where the high coil is if any one no's, i cant find it any where, would i be rite in saying that its ontop of the starter motor?
Paul connell
Posted By: howie ll
Date Posted: April 23, 2009 at 11:32 AM
Top of my head,
12v+ = Red
Ign 1 = Black or BLACK/ blue
ign 2 = BLACK / YELLOW
Starter = RED / black
Acc =Thin red or yellow/red
Use a 556U and set it up for european cars, don't use the loop
All above from ingition switch, remove at least top cowling (PITA)
Door locks  neg in plug in DKP from driver's door
door contacts, think BROWN / white driver and pass kick panels diode together.
trunk, go to trunk, hood, might need a switch unless there's an existing, either front rail or hood lock mech (microswitch mounted there)
Lock wire, extend time for comfort close
Tach, go to one of the odd coloured injectors (one wire will be the same on all 4 injectors, don't use this)
If you have a factory alarm, disconnect the folowing:- Indicators (BLACK/ green and black white), horn, unltrasonics.  It will trigger otherwise when you remote start.  If there is a factory alarm, you can also pick up door , poss hood and trunk contacts there
Posted By: p4u1c
Date Posted: May 31, 2009 at 8:25 AM
HI Howie 11, sorry for the late reply but thanks for your reply and help on my wiring problems, im off to install them now and will let you no the outcome, once againg thankyou.
Paul connell
Posted By: p4u1c
Date Posted: May 31, 2009 at 9:44 AM
HELP ME im trying to fit my alarm to the ignition i have been given a wire diagram from howie but im stuck, alot of the wires are diffrent, the wires i have follow
Thin Blue - Coded 50
Thin Grey - Coded P
2 X Thick Red - Both Coded 30
2 X Thick Black\Red - Coded 75 & 50B
1 X Thick Black - Coded 15
1 X Thinish Brown\Red - Coded 86S
If any body can help me by telling me what each wire is, i need to no what one is the:
12V+
IGN 1
Starter
Acc
as i have my car in bits and i dont want to put it all back together to take apart again, please if you can help let me no.
Paul connell
Posted By: howie ll
Date Posted: May 31, 2009 at 12:00 PM
Ignore the thin blue and thin grey, don't know what the blue does but the grey feeds the turn lever for the parking lights and it shuts down with ignition.
Thick reds are 12V+ Input.
Thick BLACK/ red look again and one (75) is the starter and it's RED / BLACK.  The black red is 2nd ignition. If I'm wrong and they are both the same colour, one will go live with ignition, dump whilst cranking then go live again with engine run. That's your 2n. ignition. The other will go hot (i.e. 12v+) when you turn the key to the start position.
Thick black is 1st ignition.
BROWN / red is ACC.
Whilst you've removed the cowling, see if there's an antenna around the ignition switch cylinder with two thin wires leading to it.  If so you have a transponder and you will need a transponder by-pass. The best unit for that vehicle is the DEI 556U set up Euro fashion without the antenna loop. The numbers you gave after the wires are DIn/ISO standard nomenclature.
The coil:- if there is one will be mounted to the rear vertical engine bulkhead, driver's side.,use the terminal (I assume for tach) that isn't marked 15 or +.  If no coil you will have to go to an injector plug.  There are 4, each with two wires. One colour is common to all, don't use it, use any of the others.
