2008 civic immobilizer bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113564
Printed Date: May 14, 2026 at 9:15 PM
Topic: 2008 civic immobilizer bypass
Posted By: pilot288
Subject: 2008 civic immobilizer bypass
Date Posted: May 02, 2009 at 11:03 PM
I have an 08 civic, and am trying to put in a remote start. I have an xpresskit canmax 400 bypass kit, but it has the wrong firmware on it. I told them I had an 08 civic, and they gave me one with DLPKKICH8 on it. I got the instructions off the xpresskit website for my car, and wired up as written, but the unit isn't programming. Is this just because I have a unit with a different firmware on it. Just to be sure that I have the right wiring, I hooked up the SINGLE WIRE CAN to a light green wire in the car, and the immobolizer data wire to a pink wire in the car. (pins 3 and 4 if I am looking at the harness properly. The pink wire MUST be right, as it is in pin 4 no matter which way you have the harness. The other wire might need to be moved to a blue wire in the car, if I am looking at the harness wrong. Any input would be helpful. I am hoping if I just get the unit flashed with the right firmware, that I am golden. Thanks!
------------- XXXOOO
Posted By: Big Dog
Date Posted: May 04, 2009 at 1:45 PM
You need the 400.Honda4 firmware which can only be flashed with an XKLOADER2 the regular XKLOADER won't work. Here's the correct install guide https://www.bypasskit.com/getdocument.aspx?documentid=1085 ------------- Prepare your future. It wasn't the lack of stones that killed the stone age.
Posted By: pilot288
Date Posted: May 04, 2009 at 1:58 PM
Thanks. I am going by the shop I bought the kit from to see if I can get if flashed with the right firmware. Are you familiar with the colours I should have hooked up to?? According to the pdf file, I need pins 3 and 4, but it doesn't show which side the connector clip is on, so I might be looking at the clip backwards. I have used pins 3 and 4 with the wire on the far laft being pin one, and this is the wire closest to the steering column. ------------- XXXOOO
Posted By: Big Dog
Date Posted: May 04, 2009 at 2:27 PM
It's the lime green connector at the ignition switch. Pin 4 is a pink which almost looks like an orange. Pin 3 is a light green if memory serves correctly. Pin 1 is a black wire.
