1996 ford falcon xh ute xr6
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113965
Printed Date: May 13, 2026 at 7:47 PM
Topic: 1996 ford falcon xh ute xr6
Posted By: dj biohazard
Subject: 1996 ford falcon xh ute xr6
Date Posted: May 23, 2009 at 1:12 AM
1996 ford falcon xh ute xr6 i have bought a car alarm with a remote start, and it is wanting me to hook up a "start check". And i am stuck on finding the battery indicator as that is what the alarm is looking to hook up to.
Posted By: howie ll
Date Posted: May 23, 2009 at 2:19 AM
If this system doesn't have a "tach" wire for tach sensing, don't install it, it won't work.
Date Posted: May 23, 2009 at 4:47 AM
i am unsure on what you are refering to. the alarm unit has a wire for sensing this but i do not know where to find the cable in my ute to hook it up to.
Posted By: howie ll
Date Posted: May 23, 2009 at 1:00 PM
Strangely enough, I can find no info on your vehicle, either here or on Directechs. 2 questions:- Petrol or diesel, petrol with injection and does the vehicle have a tachometer (rev counter)?
Date Posted: May 23, 2009 at 3:32 PM
yea very strange. it may have soming to do with the veichle only being made for 1 year but ya still would of thought that there would be some sort of manuel on the internet. 2 answers:- Petrol and yes it does have a tach altho it is a sealed eletronic dash making it hard to find the right wires.
Date Posted: May 23, 2009 at 3:58 PM
sorry its petrol with injection
Posted By: howie ll
Date Posted: May 23, 2009 at 5:52 PM
OK, it wil either have a coil, distributor side connector also maked - or you will have 1 injector for each cylinder. One wire will be a common colour for each injector. It's the other wire you want, any injector will do. Incidentally, did the Falcon have a Mercury "sister" car that was made for longer? There might be info on that and they are probably the same as regards wiring, in the UK all current Fords share wiring except the Focus RS which shares an engine with Volvo and ignition system with Volvo and Land Rover Freelander.
Date Posted: May 23, 2009 at 6:32 PM
kool ill give that a go when the rain stops. im not sure on the sister car havent seen or heard of one for this model. i will let you know how i get on thanks
Date Posted: May 23, 2009 at 8:45 PM
ok we have sorted that problem now. yay. now i have found another problem the factory imobililser, any ideas where they hide them or how to dissable them
Posted By: howie ll
Date Posted: May 24, 2009 at 2:31 AM
Only with a deicated Ford Pats system by-pass from Fortin etc.
