2002 ford econoline e 250
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115160
Printed Date: April 30, 2026 at 11:15 PM
Topic: 2002 ford econoline e 250
Posted By: ems4ty
Subject: 2002 ford econoline e 250
Date Posted: July 18, 2009 at 12:18 PM
I checked the Vehicle Wiring Database and didn't see it, so does anyone have a wiring diagram for a 2002 Ford Econoline E-250?
Thanks,
Tyler
Posted By: iteetwo
Date Posted: July 18, 2009 at 4:06 PM
ECONOLINE       1997 -2003
KEY       T-HARNESS       IMMOBILIZER
FD KEY-1 (1999-2003)       (97-01) FD-1 (02-03) FD-2       N/A
PART       COLOR       LOCATION       DIAGRAM
12 VOLT CONSTANT       YELLOW (+)       IGNITION SWITCH HARNESS
STARTER       WHITE/ PINK (+)       IGNITION SWITCH HARNESS
STARTER 2       N/A
IGNITION 1       RED / GREEN (+)       IGNITION SWITCH HARNESS
IGNITION 2       BLACK/ GREEN (+)       IGNITION SWITCH HARNESS
IGNITION 3       N/A
ACCESSORY /HEATER BLOWER 1       GRAY / YELLOW (+)       IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2       N/A
KEYSENSE       N/A
PARKING LIGHTS ( - )       N/A
PARKING LIGHTS ( + )       BROWN (+)       IN DRIVERS KICK PANEL, HARNESS to REAR of VEHICLE
POWER LOCK       RED (TYPE C)       IN EITHER KICK PANEL
POWER UNLOCK       BROWN (TYPE C)
DOOR TRIGGER       BLACK/ LIGHT BLUE (+)       @ PIN SWITCH or COURTESY LIGHT
DOMELIGHT SUPERVISION       USE DOOR TRIGGER
TRUNK RELEASE       N/A
SLIDING POWER DOOR       N/A
HORN       DARK BLUE (-)       @ STEERING COLUMN HARNESS
TACH       WHITE/ PINK       @ CTO Test Connector
WAIT TO START LIGHT       N/A
BRAKE       GREEN (+)       @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM       DARK GREEN/ PURPLE (-)
ANTI-THEFT       N/A
