2000 dakota headlight wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115442
Printed Date: May 01, 2026 at 7:52 PM
Topic: 2000 dakota headlight wiring
Posted By: jtettenb
Subject: 2000 dakota headlight wiring
Date Posted: August 03, 2009 at 7:55 PM
Im looking for a wiring diagram for a 2000 dodge dakota. My headlights will not light up, even after they have been replaced and all fuses have been checked.
Posted By: i am an idiot
Date Posted: August 03, 2009 at 10:06 PM
Do the parking lights work? Have you looked into the failure rate of the light switch?
------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Posted By: jtettenb
Date Posted: August 03, 2009 at 10:55 PM
The parking lights do work, just fine. I have considered both the switch or a possible ground somewhere in the wiring. I figured I would trace out the wiring first since Im not sure how I would go about replacing the switch.
Posted By: howie ll
Date Posted: August 04, 2009 at 1:48 AM
Sorry to sound anal but check ALL fuses, not just those marked with lighting icons. I recently lost inst. panel lighting, front and rear fogs on my Gallant. Rear fog light relay and fuse were OK, but I discovered that the rear running light fuse had blown and they were OEM wired in series! Also look at switch.
Posted By: richl68
Date Posted: August 04, 2009 at 11:22 AM
| Parking Lights (+) | BLACK / YELLOW |  | behind fuse box |
| Hazards |  |  |  | | Headlight | light green | - | steering column |
