99 Mustang, Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116922
Printed Date: May 02, 2026 at 1:48 AM
Topic: 99 Mustang, Alarm/Remote Start Wiring
Posted By: mike636r
Subject: 99 Mustang, Alarm/Remote Start Wiring
Date Posted: October 13, 2009 at 1:16 AM
I'm trying to install a Marksman m11 remote start/alarm and a 556uw universal remote start interface module for a (3.8 99 Mustang convertible).
I already used/tried to use some of the wiring diagrams but most of them
didn't match my wires,the ones that matched were the ignition wires,from there on,nothing was of use..Does anyone have The wire and (GEM Module) wire location and pin #..diagrams for this car?
Any Info would be appreciated..
by the way the Pats system just kicked in..GreaTT.called the dealer and i might as well buy a new car..What a RIPOFF..$130 just to program
the key...if anyone knows how to bypass this please let me know..
Stage 3 body kit,side exhaust,Roush lowering springs,k&n filter,ported & polished throtel body.and gonna add a cobra supercharger.
Posted By: i am an idiot
Date Posted: October 13, 2009 at 4:50 AM
What color wires do you have at your ignition switch harness? It would help us to make sure we do not give you the same bad info you have been getting.
Posted By: mike636r
Date Posted: October 13, 2009 at 12:17 PM
Igni..
3)yellows
2)light gray / YELLOW
1)WHITE/ pink
2)light GREEN/ purple
1)RED / light green
1)RED / black
1)BLACK/ light green
the problem i have is the the wiring info for the rest like the (gem module)don't match my wiring.Ex..the alarm dissable wire is supposed to be at the (gem )20 pin #16 GREEN/ violet..well i looked and there isn't such wire there at all..Ex.the other wiring diagrams said
the alarm dissarm wire is at'
Alarm Disarm GREEN/ VIOLET (-) LEFT KICK PANEL'' this wire doesn't exist either....
so i was thinking that the diagrams listed here are for the coupe only,i honestly thought the wire for the 99-04 v6 coupe or conv..were the same....can anyone shed some light on this...
Date Posted: October 14, 2009 at 7:03 AM
 | Battery | | YELLOW | | (+) | | OR LT.GRN/VIO IGNITION SWITCH | | |  | Ignition 1 | | RED / LIGHT GREEN | | (+) | | IGNITION SWITCH HARNESS | | |  | Starter 1 | | WHITE/ PINK | | (+) | | IGNITION SWITCH HARNESS | | |  | All Door Trigger | | BLACK/ WHITE | | (+) | | 20 PIN CONN. PIN 3 AT THE GEM MODULE UNDER THE LEFT SIDE OF DASH IN DRIVERS KICK PANEL | | |  | LF Latch | | YELLOW/BLACK | | (-) | | 20 PIN CONN. PIN 13 AT THE GEM MODULE UNDER THE LEFT SIDE OF DASH IN DRIVERS KICK PANEL | | |  | RF Latch | | GRAY/RED | | (-) | | 20 PIN CONN. PIN 5 AT THE GEM MODULE UNDER THE LEFT SIDE OF DASH IN DRIVERS KICK PANEL | | |  | Trunk Trigger | | BROWN / WHITE | | (-) | | GEM MODULE POS 3 LEFT SIDE OF DASH | | |  | Alarm Disarm | | GREEN/ PINK | | (-) | | DRIVERS KICK PANEL | | |  | Parking Lights | | BROWN | | (+) | | LIGHT SWITCH OR DRIVERS KICK PANEL |
Posted By: tommy...
Date Posted: October 14, 2009 at 7:52 AM
Posted By: tommy...
Date Posted: October 14, 2009 at 7:55 AM
Does your key have the little door on the top...Where the chip would be...If so...You could permently bypass it...Then if you ever need a 2nd key made...You could just get a metal key cut...Although your are losing a step of security...So just add a starter kill and your golden(kinda)...! The car defitnely has factory security...?? Roll window down...Press lock on the door switch...Shut the door...Wait 60 seconds...Open door...Is it honking at you...?
------------- M.E.C.P & First-Class
Posted By: mike636r
Date Posted: October 14, 2009 at 8:53 PM
First of Thanks for anyone who has replied..
When i said the 'pats system kicked in' i should of been more specific.sorry..when i try to start the car with the original key,the only thing that happen's is the motor 'cranks' but doesn't run..as soon as i turn the key to 'start' run' the ''Theft'' starts to blink really fast,for about 2-4 mins.. then it blinks normally again...So i know its a 'pats' system problem..
Erlier today i went and got a code reader..I pluged it in and no codes would show.....Now i'm getting really mad..so i removed the remote start and tried the factory set up...plugged in the code reader again and no codes would come out,it would just freeze the code reader every time...
when i look at the dash,the service engine light is on,the battery lightand the theft light blinking really fast ...
Tommy-I just tried the put down window thing and no it didn't honk..
-about the key,yes it does have a little square door looking on the top of the key...
you said i could permanately bypass it for good?? well,as far as things are looking right now i think i might justa try it..im not worried about my car being stolen,i always garage my car,its never out of my sight sort of speak...pm me and let me know how to do this bypass.
Thanks in advance!
Posted By: mike636r
Date Posted: October 14, 2009 at 10:08 PM
also,is it possible for you guys to help me in directing me to install this system? The only thing i can't get to work is the remote start,to start..Everything else like the paging feature,doorlock/unlock,etc..worked just fine..
assuming i can get the car to start runnin on gas and not on a battery lol.thumbs up on the 3 year warranty on the battery wich came pretty handy today....
i know how how this all may look like i don't know anything about cars..and you are right..i only know motorcycles but i wan't to learn how to wire car electronics too...i know how to rebuild a cars engine but when it comes to the electronis part im clueless...
if anyone thinks they can help with the remote start feature of this install ,p.m me.. (marksman m11 remote start on a 99.3.8lt conv.mustang)
~Thanks in advance!
