s10 remote starter wiring diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=117209
Printed Date: May 01, 2026 at 7:51 PM
Topic: s10 remote starter wiring diagram
Posted By: corvairbob
Subject: s10 remote starter wiring diagram
Date Posted: October 24, 2009 at 4:12 PM
i have a Chevy s10 4 cylinder automatic i don't know if it has a security system but in the instrument cluster i see a security light up in the left hand upper side.
i need to locate a wiring diagram so i can install a commando ez-2500 remote starter in this truck.
unless someone here says this remote starter will not work. if so what would you recommend. thanks
Date Posted: October 24, 2009 at 4:14 PM
opp's i forgot to tell the year. it is a 2000 chevy s10 4 cylinder with automatic. power windows,mirros,cruise, if that maks any difference.
Posted By: howie ll
Date Posted: October 24, 2009 at 6:30 PM
DEI 1100 will do, see the vehicle wiring charts here.
Posted By: syl20rochon
Date Posted: October 24, 2009 at 6:45 PM
FUNCTION DATACOLOR LOCATION POLARITY PICTURE
+12 Volts: Red Ignition Harness +
Ignition: Pink Ignition Harness +
Ignition 2: Pink/White or White** Ignition Harness +
Accessory: Orange Ignition Harness +
Accessory 2: N/A
Starter: Yellow Ignition Harness +
Tachometer: White or WHITE/ Black Coil AC
Parking Lights: Light Blue At switch +
Brakeswire: White at switch
Lock :Light Blue driver's kick panel or keyless entry module +
Unlock :White driver's kick panel or keyless entry module +
Arm :Tan*** Driver's Door Switch -
Disarm: Light Green In driver's door boot -
Doorpin: White Courtesy light -
Security: OEM ALARM,PASSLOCK II
Comments: * VEHICLE IS EQUIPPED WITH PASSLOCK II ANTI-THEFT SYSTEM.
** 2ND IGNITION MUST BE CONNECTED FOR REMOTE START OR CHECK ENGINE LIGHT WILL TURN ON AND DRIVEABILITY PROBLEMS WILL BE EXPERIENCED, POSSIBLY RESULTING IN SERIOUS TRANSMISSSION DAMAGE.
*** PULSE AT SAME TIME AS LOCK..
Sylvain Rochon
MECP security specialist
Tech support for remote starters
26 Years of experience counts
I'm here to help.
