prostart 2 button
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118022
Printed Date: May 16, 2026 at 2:29 PM
Topic: prostart 2 button
Posted By: wiesh
Subject: prostart 2 button
Date Posted: November 26, 2009 at 12:04 AM
I hooked up a proatart system with 2 igntion output to a 1997 ford Taurus, which has 3 ignition wires, but I only used 2, The Blower doesn't work I need the third ignition wire hooked up, I can disconect the 2nd wire and hook it up to the third. I would like to have all three wires hooked up. Can I use a diode to go from the the second ignition wire to the 3rd? Or do I use a relay? Is there a diagram that shows how? Thanks
Posted By: KPierson
Date Posted: November 26, 2009 at 7:14 AM
You need to use a relay - a diode won't be able to safely carry the current.  You can use the IGN2 output to trigger the relay.
Kevin Pierson
