2009/2010 cr v fuse box
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118254
Printed Date: April 16, 2026 at 1:33 AM
Topic: 2009/2010 cr v fuse box
Posted By: macguitar
Subject: 2009/2010 cr v fuse box
Date Posted: December 05, 2009 at 1:57 PM
In the fuse box of the 2009 or 2010 CR-V, in the upper left, there is a 6-pin connector for accessories (like the self-dimming rear view mirror).
I need a diagram showing what each pins is used for.
I want to take the Honda self-dimming mirror harness and splice it into a harness for a Gentex mirror (so I will splice the harness rather than the vehicle wires, and then it's plug and play!), but I need to know what the pins are in that connector.
Here is an image showing the location of this connector:
posted_image
Thanks in advance!!
Michael
Posted By: kreg357
Date Posted: December 11, 2009 at 7:16 PM
I looked in the 2007 Honda CR-V Service Manual but everything says "not used" for that connector.
I might be able to help a little bit.  I purchased a JDM (Japan Domestic Market) fog light kit to install on my 2007 CR-V.  It did not include the Directional/Head Light Stalk assy like the US market kits do ( or instructions for that matter).  It had a seperate dash mounted switch for turning on the Fog Lights.  Anyway, it had a blue 6 pin plug with 2 wires that fit nicely it that open connector you asked about.  Here is a picture and what I figured out.
posted_image
The RED / Black wire (upper right corner) will give +12v whenever the parking lights or low beam head lights are on.  The other wire (white) will give +12V constant (with IGN on, I think) if you plug a fuse into position 27, marked with red arrow.
I am not sure if they changed anything between 2007 and 2009/2010 internally but the fuse box looks the same.
Good luck!
