2006 impala wire verification
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118778
Printed Date: April 30, 2026 at 11:32 PM
Topic: 2006 impala wire verification
Posted By: steezs
Subject: 2006 impala wire verification
Date Posted: December 23, 2009 at 11:04 PM
Hi, I am doing a remote starter on a 2006 Chev Impala. I am using an Autostart and an IDATA PL module Wiring type 9. I got everything to work except the transponder bypass. In the car there are 2 harnesses at the ignition exactly the same as the diagram in the Idata guide for the PL module type 9 wiring.The problem I am having is that the Idata module will not program, it stays lit solid red during programming which tells me it is missing info from the car like a wire is not hooked up or something.I have soldered all my connections and I have to talk their tech support. They say I only need the data and ignition wires hooked up to program the module. I have tried everything, however looking over the car tech data and the Idata sheet I have seen perhaps an error in the wire colors. In the car tech data it says the starter is a white wire at the ignition harness but the Idata wiring diagram says the white wire is PASSLOCK. I was wondering if PASSLOCK is the same or does the same functions as the starter wire or could I be hooked up to the wrong wire because there is also a WHITE/ BLACK wire beside the white one. This seems weird also because the tech from IDATA says I only need the DATA and Ignition wires hooked up to program the module.
THE DUCE
Posted By: carstereoguy
Date Posted: January 04, 2010 at 9:22 PM
you do not need the starter wire as there is none at the ign
the white wire is the passlock the pink is ign the brown is ign
i own a 2007 and ive done a few pm me if you have too many problems
Posted By: steezs
Date Posted: January 04, 2010 at 9:27 PM
Thanks man, but I spoke with a better tech support guy the next day and he told me sometimes the PL modules don't work on these cars, so I used a GM one with the ignition wrap and it works.
THE DUCE
