2005 mercury montego premeir awd
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=121523
Printed Date: May 08, 2026 at 4:19 PM
Topic: 2005 mercury montego premeir awd
Posted By: squirlydude1974
Subject: 2005 mercury montego premeir awd
Date Posted: April 26, 2010 at 2:27 AM
wiring info to install remote start with allarm, door locks, trunk.  Car has remote entry with alarm and trunk allready have an old designtech system that has worked with out fail for years in several different vehicles.  I submited this request about an hour ago but the system was down for updates and i am unshure if it was recieved.  thanks for your time and hard work over the years i have used your site many times and have told many others of your site.
Posted By: 91stt
Date Posted: April 27, 2010 at 11:32 PM
Circuit           Wire Color    Location
  Constant 12 volts     RED (30AMP)           IGNITION SWITCH HARNESS
  Ignition 12 volts   LT GREEN/ VIOLET        IGNITION SWITCH HARNESS
  Starter DK GREEN            IGNITION SWITCH HARNESS
  Dome Light        BLACK/ LT BLUE (+)        AT SMART JUNCTION BOX *
  Driver's Front Door
  Pass Front Door Pin
  Driver's Rear Door
  Pass Rear Door Pin
  Trunk Pin          SWITCH BUILT INTOTRUNK LAMP
  Parking Lamp        ORANGE / BLACK (+) AT SMART JUNCTION BOX IN 32 PIN CONN*
  Lock PINK/LT GREEN            DRIVER'S KICK PANEL
  Unlock PINK / YELLOW           DRIVER'S KICK PANEL #201
* SJB Is Behind Driver's Dash To Left Of Steering Column
#201- See Negative Pulse Door Lock Diagram
 Tach Signal          ANY WIRE NOT RED           AT EACH COIL #239
  Ignition #2NONE
  Ignition #3NONE
  Accessory             GREY / YELLOW       IGNITION SWITCH HARNESS (BLOWER)
  Accessory #2
  Accessory #3
  Starter #2
  Neutral Safety       LT BLUE / YELLOW      AT POWERTRAIN CONTROL MODULE *
  Brake Light          RED / LT GREEN        AT SWITCH ABOVE BRAKE PEDAL
  Parking Brake
  Clutch Pedal
  Reverse Light       WHITE/ YELLOW (+)        AT SMART JUNCTION BOX **
  Rear Defrost            PINK (+)AT DEFROST SWITCH
* PCM Located On Top Of Rear Of Engine ** SJB Located Behind Drivers Dash To Left Of Steering Column
#239- See Transponder Type Immobilizer Bypass Diagram Passive Anti Theft Wires Are TX-WHITE/ L GREEN And RX-GRAY/ORANGE.
Date Posted: April 28, 2010 at 12:00 AM
Thank you 91stt for taking the time to do this for me.
