2006 lincoln zephyr w/nav
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123139
Printed Date: May 02, 2026 at 12:12 PM
Topic: 2006 lincoln zephyr w/nav
Posted By: nickbm3
Subject: 2006 lincoln zephyr w/nav
Date Posted: August 16, 2010 at 3:48 PM
Hi all,
I need factory stereo wiring for a 2006 Lincoln Zephyr WITH factory navigation. Do these still have a 12volt radio turn on wire? Also id really like to know if there is a working MUTE input wire in the factory harness as well (im installing a hands-free bluetooth kit).
The unit i will be installing is a Bury Technologies CC9060, if anyone has the installation instructions that they could post that would be really helpful to since i dont have the product yet.
Thanks!
Nick
Posted By: Ween
Date Posted: August 19, 2010 at 10:57 PM
hi,
i believe it has an accessory lead at the radio. pin 7 at the main radio connector should be mute..(-) trig. there probably isn't a terminal in the radio harness.
m
Posted By: nickbm3
Date Posted: August 22, 2010 at 10:47 PM
Thanks for the reply, unfortunately i already did the install when i saw this.
Is there any way to get more volume output on a handsfree kit that plays through factory speakers when the factory speakers are 8 ohms? Can you bridge the handsfree kit to one speaker?
Posted By: Ween
Date Posted: August 23, 2010 at 11:55 AM
bridging the hf kit isn't possible i'd guess.  try and mute the entire system and have the hf play into high efficiency 4 ohm external speakers?  i'd think trying to wire in a high level booster amp would open up all sorts of problems.
m
