keyless entry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123977
Printed Date: April 02, 2026 at 1:14 PM
Topic: keyless entry
Posted By: phenom71ca
Subject: keyless entry
Date Posted: October 17, 2010 at 3:39 PM
2000 hyundai, trying to hookup the keyless entry. - pulse fromt he alarm.
the switch is in the door. unlocks  all doors or locks
there are 4 wires in the door
blk -
blue + constant
white + on lock
yellow + on lock
what type of system is this , and how many relays and what configuration would i use.
tia
Dave
Posted By: i am an idiot
Date Posted: October 17, 2010 at 4:00 PM
2000 Hyundai _____?
Posted By: howie ll
Date Posted: October 17, 2010 at 5:45 PM
Craig, I can't work out what's going on here, assuming an actuator in each door that wiring is wrong, I'd look for 2 wires that pulse neg one on lock, one on unlock. They should be in the loom coming through from the driver's door. Unless the poster really means yellow + on unlock and do those two, white and yellow sit at ground at rest? If so it's 5 wire (relay interrupt) type.
Model should help.
And since when are we aunties (tia)?
Date Posted: October 17, 2010 at 7:05 PM
its a2000 hyundai accent.
sorry about that
Date Posted: October 17, 2010 at 7:07 PM
and they are ground at rest (yellow and white)
Date Posted: October 17, 2010 at 7:18 PM
Are they aftermarket door locks?   Audiovox has no info for door locks in that vehicle.
Date Posted: October 17, 2010 at 7:22 PM
no they are factory
Date Posted: October 17, 2010 at 7:27 PM
They do have this info for the 01, check before attempting.
posted_image Power Unlock BLUE (-) AT KEYLESS ENTRY MODULE TO LEFT OF STEERING COLUMN posted_image
posted_image PowerLock YELLOW (-) AT KEYLESS ENTRY MODULE TO LEFT OF STEERING COLUMN
Date Posted: October 17, 2010 at 7:40 PM
i will have a look tomorrow, this is a wierd system. if you unlock the driver side with the key
it unlocks all the doors. the switch is in the driver door. I think i will just wire in another actuator.
i was hoping not too. but it looks like the was to go. unless someone else knows this type of system.
tia
Date Posted: October 17, 2010 at 8:07 PM
It is common to have to install an actuator in the drivers door.  Earlier you stated that the switch locked and unlocked all doors.  You will probably have to install an actuator in the drivers door.
Posted By: howie ll
Date Posted: October 18, 2010 at 3:39 AM
Just go with what Mr. Idiot said about blue and yellow at the KE module, you should have gone there first, you shouldn't need an actuator, you've actually gone about this back to front and I don't think you tested those wires properly initially.
